Hello:
I’m participating in Challenge 15.
I’ve added a Line Chart that I’d like to use to display different types of data in the Line Chart. The type of data to be displayed will be controlled by buttons to display the appropriate type of data. Specifically, it one instance, I want to display Avg Lap Time, in another the % of Race Starters who finish the race, in the third the % of Laps Completed by All Drivers.
That is, same visual, displaying a different flavor of data.
My problem is as fundamental as it gets. I can’t add the Bookmarks for each data type to be displayed properly.
I display the report page with the Line Chart displaying the Avg Lap Time measure and Add the Bookmark.
I repeat after swapping out the measure for Avg Lap Time for the % of Laps Completed Measure, and Add the Bookmark.
I repeat after swapping out the measure for % of Laps Completed Measure for the % of Starters Who Finish Measure, and Add the Bookmark.
After doing, I click on each bookmark, but there’s no change in the Visual. I haven’t reached the point of wiring the Button to a bookmark.
I’ve watched several tutorials today discussing Bookmarks. It all seems so simple. I’ve reviewed th
Challenge 15 Work.pbix (5.7 MB)
e PBIX files of other Edna members, again it seems so easy.
Here are my PBIX and underlying data file.
As far as a mockup, all I want is for each bookmark to display the data as it related to the relevant measure.
Formula 1 Data.xlsx (22.8 MB)
Thank You.
John Giles
Before you send your question.
Make sure that all details relevant to your question is complete:
- Your current work-in-progress PBIX file - VERY IMPORTANT
- A clear explanation of the problem you are experiencing
- A mockup of the results you want to achieve
- Your underlying data file
Also make sure that your data file contains no confidential information. If it does, click the link above.
*** DELETE THIS MESSAGE IF YOU ARE SURE ALL YOUR DETAILS ARE COMPLETE OR IF THE ABOVE INFORMATION IS NOT APPLICABLE TO YOUR QUESTION.***
