VAR mindate = DATE([signupyear],1,1)
VAR maxdate = EOMONTH([reportingyear],[Reportingmonth],1)
VAR inperiod = DATESBETWEEN(DateTable,mindate,maxdate)
Calculate(
SUMX(
ADDCOLUMNS(
SUMMERIZE(DateTable),
YearMonth)
[Voorschot]*??? “multiplier”
If I would like to multiply the first month by the difference of months in the selection
FILTER
Jan - May
Jan * 5
Feb * 4
March * 3
April * 2
May * 1
How could I implement that?
Hi @Diabolica,
I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
- A clear explanation of the problem you are experiencing
- A mockup of the results you want to achieve
- Your current work-in-progress PBIX file
- Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Thank you!
Hello @Diabolica
Just following up if you still need help with your inquiry?
If you do, kindly provide the information requested above so our experts and community members can help you further.
I just recently added the PBIX and the measure that doesn’t show any values.
Can someone help me sort this out please?
