A third party has sent me an archive file of a postgres DB. I thought i would be able to restore it via SSMS and then connect Power BI to it. THis did not work and came up with errors. I know there is a connector for a postgres DB (we tried this via VPN and it didnt work hence why they sent me the backup file).
Any advice on what i need to do to the file to be able to connect it to Power BI?
Managed to get it working and for anyone else with the same problems it came down to certification. I needed to import the certificate into the windows certificate store. Interested to know if anyone else has had this issue before or needed to do it. Was a first for me…
Hi @Hitman, did the response provided by @ankit help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Hitman, we’ve noticed that no response has been received from you since Aug 5. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Hitman, due to inactivity, a response on this post has been tagged as “Solution”.
