Connect data using Rest API. How to programatically refresh Bearer Token?
Good afternoon,
I am getting some data using a REST API that required a bearer token.
The issue I am having is that I will need to update the token that will expire.
Any thought on how to update the token?
Thanks in advance,
Ezequiel
Hi @ezenunez
Please check this video
Thanks Jose,
I do not have access to Azure, but I will have a chat with colegue.
cheers,
Ezequiel
Hello @ezenunez, just following up if the response from @jbressan help you solve your inquiry?
If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
