Dear DNA Team,
Cumulative Totals Across Averages & Dynamic Date Logic - Advanced DAX.pbix (461.7 KB)
Is it possible to apply conditional formatting to Line Chart type visualization? I would like to show positive and negative numbers using different colors.
I am aware that this is possible using stacked columns visualization.
Thank you for your help.
MateusZ
Hi Mateus,
You created a column chart firstly, then apply the conditional formatting, then switch it over to a line chart.
the link below should show you
Thank you @DavieJoe simple trick
I did noticed the conditional formatting is not available therefore I can kind of got stuck.
Once again Thank you!
Mateusz
No worries!
