Conditional Filters - Measure
I have a dax formula which works fine.
No. of leads with booked sales this year =
VAR _CROPYEAR =
    CALCULATE ( MAX ( GROWERORDER[CROPYEAR] ), ALL ( GROWERORDER ) )
    CALCULATE (
        [Count of Total Optys],
        NOT ( ISBLANK ( GROWERORDER[ORDERNUMBER] ) ),
        FILTER ( GROWERORDER, GROWERORDER[CROPYEAR] = _CROPYEAR )
Now I want to put conditions in my above formula as shown in the comments below:
--VAR YEAR = MAX(GROWERORDER[CROPYEAR])
VAR _CROPYEAR =
    CALCULATE (
        /* I want to put these filters in my formula"
       1.  If sprint name is "Early Order Seed" then calculate "Count of Total Optys" where product is "Corn and Soybeans"
       2. If sprint name is "Seed Retention - Corn, Soybeans, Cotton" then calculate "Count of Total Optys" where product is "Corn, Soybeans or Cotton"
       3.  If sprint name is "Seed Retention - Sunflower, Canola" then calculate "Count of Total Optys" where product is "SUNFLOWER OIL"
       Something like this:
        IF(Opportunity[Sprint Name] = "Early Order Seed",
        WfMartsProduct, WfMartsProduct[PRODUCT_LINE_DESC] in ("CORN", "SOYBEANS")
       IF(Opportunity[Sprint Name] = "Seed Retention - Corn, Soybeans, Cotton",
        WfMartsProduct, WfMartsProduct[PRODUCT_LINE_DESC] in ("CORN", "SOYBEANS", "COTTON")
        IF(Opportunity[Sprint Name] = "Seed Retention - Sunflower, Canola",
        WfMartsProduct, WfMartsProduct[PRODUCT_LINE_DESC]="SUNFLOWER OIL")
How do I add these conditions? In the visual, the Sprint names are in slicer. So when the sprint name changes, I want to filter the product to those particular products that I mentioned above.
Thanks so much in advance.
-rk
Hi @rit372002, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @rit372002, we’ve noticed that no response has been received from you since the 6th of December. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
