Hi all,
I want to present a result based on a choice on the slicer, but if nothing has been selected, I want to present the average for a specific item.
sample.pbix (26.7 KB)
I appreciate your help.
Joao Monteiro
Hi all,
Joao Monteiro
This solution is based on the fact that SELECTEDVALUE allows you to return an alternate value if there is no single selected value.
Harvest Team = SELECTEDVALUE( Teams[Team], “Average” )
From this, you can branch:
Card Points =
IF(
[Harvest Team] = "Average",
[Avg Points],
MAX( 'Table'[Points] ),
FILTER( ALL( 'Table' ), 'Table'[Team] = [Harvest Team] )
Title Text = IF( [Harvest Team] = “Average”, “Chelsea”, SELECTEDVALUE( Teams[Team] ) )
Which when set as the title using conditional formatting gives this result:
I hope this is helpful. Full solution file posted below.
Hi @BrianJ
This solution is almost what I want, but not quite.
I explain why:
Regards,
Joao Monteiro
Hello @JaoMonteiro,
In the solution provided by Brian:
you see 50 when “Chelsea” is selected
When none is selected, It is presented “Chelsea” with the average points for all teams
It is not the solution you are looking for?
Hi @BrianJ
Your solution is in line with what I asked for.
I was the one who misunderstood the explanation.
I want to show it in a bar graph
Regards,
Joao Monteiro
This uses the exact same logic and measures as the card solution, just organized a little bit differently in the visual:
Full solution file attached below.
– Brian
eDNA Forum – Conditional Card Selection Solution2.pbix (26.6 KB)
Hi @JoaoMonteiro, we’ve noticed that no response has been received from you since the 15th of April. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @JoaoMonteiro, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
