Combine two different power bi files
Hi All,
I have a scenario where i need to combine two different pbix files in to one.
Please can you help with any tips if this is possible to have in Power BI.
Thanks in advance
Swapnil
@swapnil
Not sure if it’s possible. But one idea I have is, save the file you are not going to use any more as a template. Then in your main file, import that template and see what happens. No idea if that will even remotely work, so I’d do it on some back up copies of your originals.
In the November 2018 update the ability to copy visuals from different pbix files became available. Thus making one report from many - so to speak.
This may be the closest you can come
Guy
