Circular Dependency on Calculated Columns
Hello
I have read all the other forum postings on circular dependencies but I can’t find a scenario like mine.
My client forecasts quarterly and the headcount table populates as the year progresses. The dashboard contains a slicer where they can select F1, F2 or F3 and see data at that point in time so the headcount needs to reflect different time ranges as follows;
F1 = Jan-Mar
F2 = Jan-Jun
F3 = Jan-Sep
I tried to do this with three calculated columns which gives me the circular dependency, I tried measures but I can’t get the correct result, would be grateful of any pointers, thanks Lizzie
Circular Dependency.pbix (103.3 KB)
@LizzieTompsett
Hello @LizzieTompsett, good to see that you are having progress with your inquiry. Did the response above help you solve your inquiry?
If it does, kindly mark as solution the answer that solved your query.
Hi Antriksh
Thank you for referring me to the article, the REMOVEFILTERS function sorted my problem, very best regards Lizzie
