Can you create spark lines in a single column
Hello,
I would like to create spark lines in a column like you can in excel. I have 4 columns of yearly cost info and would like a spark-line in 5th column to snow the YOY trend. I’m using the Pro desktop license.
Thanks,
Brian
Hi Brain,
There is no way you can create sparklines ‘out of the box’ inside a table. But you could use SVG images to create sparklines here’s a link: SVG Image Sparklines on Rows in Power BI Tables · Havens](https://youtu.be/xLD8HKwPWHE)
Hope this helps
Melissa
Thank you.
