Hi All,
So I’ve been playing with calculation groups and made some good progress.
I’m trying to minimise the number of measures as much as I can.
I have come stuck with a little problem that I’m hoping you can help with and push me in the right direction.
So I have created a calculation group called TimeIntelligence and populated with my measures using the SELECTEDMEASURE() approach.
What I now want to be able to do is select multiple measures at the same time. Is this possible with calculation groups?
I have been playing around with the switch and have got it working pretty well when one measure is selected but would love for the user to be able to select what they like in terms of time intelligence columns and measures.
Have attached the PBIX.Calc Group Demo.pbix (124.5 KB)
Many thanks in advance.
Haroon
