Calculate Amount by not connected DimensionTable
Hello EnterpriseDNA Members,
may you help me with a solution?
I want to show the right Amount (EBITDA) from the Budget 2021 table for each OperatingRegion.
Without any Measure, the wrong numbers are shown, due to not connected tables.
So I tried to Calculate a Measure with Calculate and Filter, but unfortunately I don’t got the right result.
Here the basis of the Model:
In the Budget 2021 table are my CostUnits (DimensionCode) but no OperatingRegion.
In the factData table are the CostUnits together with the OperatingRegion.
The table dim_OperatingRegion is pulled out of the factData table.
I think there should be a simple solution, but due to almost midnight I can’t see the forest for the trees.
Thanks in advance.
Dan
@d.mesch
Enable bi directional filter from factData to dim_CostUnit
Hi @d.mesch , did the response provided by @Rajesh help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @d.mesch, we’ve noticed that no response has been received from you since the 22nd of January. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
