Average of a Measure in a Line Chart
Hi All, I have these Measure
Avg ADF 10K = AVERAGEX(VALUES('Date Table'[Date]),[2019/20 ADF])
I’m trying to average 2019/20 ADF.
I also want to use it in a chart, such that it is fixed line like this:
Which is why I created this measure:
National ADF Average = CALCULATE([Avg ADF 10K], ALL())
Breaking it down:
> 2019/20 ADF = DIVIDE([Total ADF], [Total Pop 10K] )
** Total ADF** = CALCULATE(
SUM('Dwelling Fires'[Total Dwelling Fires]),
FILTER('Dwelling Fires', 'Dwelling Fires'[Accidental or Deliberate] = "Accidental"))
Total Pop 10K = SUM(Population[Population 10000] )
Question is this:
What is the best way to calculate the Average of
“2019/20 ADF”
am I ok, using “
Avg ADF 10K
2ndly, what is the best way to fix it on a Line and column chart
PBIX file is attached showing the relationships. Thank youBenchmarking reports learn.pbix (1.0 MB)
Hello @Ikay,
I looked into your pbix file. and i thing your model is clean and simple. For the measure National ADF Average, it gives you the daily average ADF throughout all the whole time. i dont know if thats what you want to show. if it is. then your measure is correct.
Another issue i find in your report is the absense of date tilters. So, the report is not that dynamic. I did a small adjustment of your file. Hopefully that’s whe you are looking for.
@HASSAN_BI, Thank you so much this.
I just wanted some confirmation - And yes, I needed that dynamic element to it
Regards
Ikay
