I have some data of flights completed for an airline that I am analyzing and I have used distinct count to get the daily number of aircraft that are being operated. This all works fine except for on a total basis as the total in the distinct count column is the maximum amount of aircraft operated during the whole data pull rather than the average number of aircraft used in the period.
I have tried a few formula with no success and assume its an averageX type approach but any guidance on how to calculate the period average of a distinct count measure would be fantastic.
Thank you all
*** READ FIRST ***
Before you send your question.
Make sure that all details relevant to your question is complete:
Your current work-in-progress PBIX file - VERY IMPORTANT
A clear explanation of the problem you are experiencing
I cannot seem to use Average for a var. When I go to write the second line of the code: VAR _AvgDiscount = Average(_Discount) the average function will not let me populate it with the VAR or any measure for that fact.
Unfortunately I cannot as it is sensitive project information sadly.
However reading some more it appears to me Average function cannot be used on measures or variables and only used on columns
Hi @Ronan.
Instead of real data, please provide a small sample dataset and Excel mock-up of your desired results (using that sample dataset) to assist the forum members in their investigations.
Hi @Ronan, we noticed that you have not responded to the request of our community members. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hello @___. Due to the length by which this post has been active, we are tagging it as Solved. Thanks to the contributors of this post. For further questions related to this post, please make a new thread. Feel free to reopen this thread if you anyone would like to answer the pending inquiry above.
