Allselected+values+sumx can't be combined
Hi all,
I’m having difficulty calculating the year month count in a filtered period with the additional check that a measure is not blank in that period.
This is the logic that I approached my calculation but for some reason that returns
all selected expects a table reference for argument ‘1’, but a table expression was used
iMonthCount =
    SUMX (
        ALLSELECTED ( VALUES ( tMasterCalendar[YearMonth] ) );
        IF ( NOT ( ISBLANK ( [IN] ) ); 1; 0 )
2 Questions:
1.Why it doesn’t work?
2.How would you approach it?
Hi @giomil,
You’ll need to choose so either ALLSELECTED ( tMasterCalendar, tMasterCalendar[YearMonth] ) or VALUES ( tMasterCalendar[YearMonth] )
It doesn’t work because ALLSELECTED needs a Table and then a Column reference whereas VALUES returns a Single column Table. Here you’ll find more on ALLSELECTED and here’s more on VALUES
I hope this is helpful.
Hi @giomil, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
