Advanced Data Transformations & Modeling >> 27 Intermediary tables
I found there was some kind of discontinuity as I have watched the entire series.
I found that till 26 Measure Group the video I can follow but suddenly COUNTRY and 2016 Regional Budget into came in Data Model.
Although using your video, I am able to create a new COUNTRY table.
But for the 2016 Regional Budget, I get this error. I have downloaded your Advanced Data Transformations & Modeling.pbix file as reference.
DAX comparison operations do not support comparing values of type Text with values of type Integer. Consider using the VALUE or FORMAT function to convert one of the values.
Any advice, please.
