Hello,
In this video, Sam talks about the lookup tables…
He mentions about de-normalizing the data. Is that correct? I thought having lookups helps to normalize the model…
Thank you
Hello,
Thank you
De-normalising the table is another way to describe breaking out a single table into multiple tables to create a model
Hi @arkiboys , did the response provided by Sam help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
