Power Bi Dashboard - Sync Slicers
Hi Sam
Greetings !
Is this possible to do in Power Bi?
I am creating a ‘What if Scenario’ for 5 Products. Product 1 on page 1; Product 2 on Page 2 and so on…total of 5 pages using same data set.
Why single Page for each Product: Reason is i want to change price and cost for each Product to find profit scenarios separately.
Then i want integrate all 5 Pages ‘what if’ outputs on a Single Dashboard using each page scenarios.
is it possible?
Bet regards
kuldeep
Yes this is possible.
You need to use the ‘sync slicers’ feature to get this to work across different pages.
See the below link for information on how to sync slicers
Thanks a million Sam
It works
Best regards
kuldeep
